leftside
Easy decision for me. I'd go for the $174 pair and use them. Those are GREAT tubes btw. Definitely one of my favorite 6SN7 and I often use them in my preamp. I prefer them over the earlier and more expensive metal base version.As a neophyte tube amplifier owner, I have another question.
I noted that you stated that you have older tubes that test low, but sound better than new NOS 100% testing tubes.
That made me wonder about decision-making choices when buying tubes from an e-bay seller.
For example, let's presume that I decided to purchase a pair of Sylvania V231 6sn7GT tubes for my Cayin HA300MK2 headphone amplifier.
Here is a listing for an used set for $174 for a matched pair - https://www.ebay.com/itm/225287178877?epid=1729696074&hash=item3474298a7d:g:oAwAAOSwQ2djkXny
I noted that the seller had another set that was labelled brand new, that was selling for $358 for a matched pair.
What are the pros and cons of buying the used set versus the brand new (unused) set?
Jeff.
The newer version will hold their price much better as long as you don't use them. Collectors pieces. I have lot's of tubes I use, but I also have a few NOS/NIB tubes that I will never use. I consider these to be more antiques/historical artifacts.
Edit: Just beware the tube on the right has seen a lot of use. I can tell by just looking at the top of the glass. A new tube of that type will be completely clear. The base has also seen better days. After looking at the pictures, I wouldn't buy this pair of tubes.
