The Reference 6SN7 Thread
Feb 7, 2023 at 8:39 AM Post #8,417 of 10,650
is anyone familiar with any of the newer production 6SN7 tube by Psvane , Linlai or from EH and Tung sol? im curious if they are any good.
The Linlai is a well-balanced tube. Great alternative to some NOS tubes
Feb 7, 2023 at 9:14 AM Post #8,418 of 10,650
Great thanks for the info. Do you know if they are alot wider in size than standard 6sn7s I'm trying to see if it will fit in my TA26 with shouldered power tube
Feb 7, 2023 at 9:25 AM Post #8,420 of 10,650
The power tube I have is a RCA 6AS7G bottle shape
Feb 7, 2023 at 9:44 AM Post #8,422 of 10,650
Ive done it with 400 sand paper. I put the pin inside the crease the sandpaper creates when folded and sanded all the pins down. It worked like magic. Thanks guys!
I use to clean them afterwards with electronic spray on a cotton bud. This removes a lot of dirt that won't accumulate in the amp socket.
Feb 7, 2023 at 5:57 PM Post #8,423 of 10,650
As with many Chinese tubes the Linlai 6SN7 comes as several variants at different price points. Does anybody know if there is any real difference between the lower priced and higher priced tubes of the same designation?
Some of the tubes are for wholesale distribution (although available from Chinese vendors) and others for individual sale, with a large spread in price.
Historically this is a new development. I’m the past you could find more rugged or longer life variants of the same tube, (and sometimes tubes with tighter tolerances and less microphonics) but not fancier packaging, print, or color schemes or different shapes (globes vs ST etc).
Feb 7, 2023 at 6:01 PM Post #8,424 of 10,650
Can you check back in 50-60 years? By then Head-Fi will have developed a holy grail canon for these models to provide the definitive 'historically-correct' answer. :sweat_smile:
Feb 7, 2023 at 6:16 PM Post #8,425 of 10,650
I bought mine from Grant Fidelity. I wasn't looking to hem and haw about it
Feb 7, 2023 at 6:28 PM Post #8,426 of 10,650
Was just curious on how they sound and if they are worth while alternative to vintage or NOS.
Feb 8, 2023 at 8:05 AM Post #8,429 of 10,650
Bought this tube the other day, very nice sound, but more for the reason that I already own a pair for Envy…and it just seemed logical 😜 to buy a single for the Crack! I only posting now with a few pics as I like the box. Sad I know 😀.
06DA21C6-E961-422E-9059-A03B899AFB51.jpegD1F6B400-0B77-45D7-B2B8-9E7942266CD7.jpegD0970DF9-C442-4CF9-8B4D-0B8A158C6077.jpeg
Always a fan of NU sound...have various 6SN7/VT-231 versions, 6C8G, 6G6G.
Feb 8, 2023 at 12:27 PM Post #8,430 of 10,650
I personally would clean them using deoxit which is a cleaning spray for electronics. If you don't you could end up corroding the socket in your amp
Be very careful that deoxit goes nowhere near the glass as it very easily removes print on the glass. Also don’t want to get deoxit anywhere near the tube sockets.
I use a Dremel with 3mm wool felt mounts. Maybe for very badly corroded pins you might want something more extreme, but I’d be very careful. Most of the tube pins I see just need a good clean.
