alvin sawdust
Many thanks for the tip. Re-flowed a Melz 1578, Marconi black glass B65 and a CBS Hytron 5692 that were all at deaths door ( or so I thought ) with crackling and static. They are now all dead quiet and sounding great. I even brought life back to a Raytheon 6528 that wouldn't fire up at all.FYI -- from what I've read, the Melz are notorious for having static. This is due to the solder and age of the tube, but it can typically be resolved by re-flowing the solder on the tube pins. You can do this by running a hot soldering iron up and down the pins to melt and re-flow the solder inside. Be sure to keep the tube in an upright position with pins pointing downward as one does not want to have solder flow into the tube. An electronics soldering vise or something similar that can secure the tube in the right position while you perform this task is recommended as it does get too hot for hand-holding. Several have reported this as resolving the static issue with their Melz tube and while I've not done it specifically on a Melz, I have done this on several older tubes that exhibited static and the static was gone afterwards.
Not recommended on a cucumber, though.![]()
Couldn't do anything with the cucumber though!
