gug42
- Jan 29, 2008
At this price, not worth it to test new production ? cv-181 TII and Z ?
Not a bargain. You can get a properly matched pair tested for noise, etc., for not a lot more than $176.
It's a bit of a gamble how he's selling them.
No, but I have an opinion anyway. First of all, if you are using the tube as a driver in some circuits - esp. the cathode follower - the driver doesn't effect the sonic signature, apart from the tube's electrical characteristics. In that case, a $18.00 6SN7 won't sound any different than a $150 one. As an output tube, the story is different, and all I can say is: avoid the expensive Chinese tubes. Buying used (or "NOS") tubes off EBay is a mine field. Avoid it. Talk with a reputable dealer. I recommend Jim McShane (google this) or "Byrd" at electrostatic69@twcny.rr.com. Of course, there are others. Another alternative is to buy a 7N7 GT or GTB and an adapter. It is electrically similar to the corresponding 6SN7 model. They were all made by Sylvania. Great tube. Good luck.
Sylvania. 1950 is too early for GTB. The type was introduced in 1954.Looking to identify this pair of Amperex 6sn7gtb's. I know they are most likely relabeled. Amperex orange world logo. Carton says country of manufacture is stamped on tube, this case it says made in USA. Possible date code 0-40 on both. 1960? 1950? Halo top getter, round mica with 6 spikes, black plates, (t plates at slight angle to each other?) 3 holes but then 2 more holes on outer edge. GE or Sylvania?
