Rob N
- Jan 28, 2002
Nice picture. That is a beautiful tube (in many ways)!
Looking at the top of the tube does it say 6SN7W or 6SN7A?
If so, prices I've found for the 6SN7W run from about $100 for rougher appearance to $150-200 for the physical condition shown in your picture. This is for tubes that test to (or very near) new electrically - regardless of appearance.
The 6SN7W was originally made for the US Navy during WWII. It also comes in black base versions (no metal base) that are tall or short bottle (glass). IMHO they rate in order: metal base, black base tall bottle, black base Short bottle. However it is very close between them and regardless of base or size, all my 6SN7W exceed all of my other 6SN7, Sylvania or otherwise (in my system). This includes the highly-rated Tung-Sol black round plate, which is my second favorite 6SN7 tube.
Never seen one with the M&R imprint you mentioned, but if it it is a 6SN7W or 6SN7A it's a winner in my book.
All IMHO.
-Eric
Very cool boxes, in very good shape!
My guess is these boxes are post war packaging. A lot of military equipment was sold as surplus and maybe Sylvania saw an opportunity selling replacement tubes.
M & R sounds similar to today's term MRO (maintenance, repair ans overhaul) used in aviation and industrial manufacturing.
The top should be printed with 6SN7W or 6SN7A.
Most importantly there should only be two holes (or rivets) per plate.
The typical WWII 6SN7W packaging can be seen here:
http://www.tubemaze.info/sylvania-chs-6sn7w-metal-base/
Hey folks, I will be buying a Schiit Audio Freya soon and would like some advice on tubes that would work great in it. The two right tubes are the differential voltage gain stage. The two left tubes are for the cathode follower output stage.
I have a nice matched quad set of NOS Sylvania 6SN7WGTA tubes from 1967 that I can use in place of the stock tubes. How good are those tubes? What tubes might be as good or better for Freya?
Which stage is more important when it comes to the tubes? The gain stage or the output stage? Should I be looking at different tube types for each stage?
I won 4 genuine 3 hole bad boys in a bid for $186.00 but before that I had purchased a pair for $140.00, so it's kind of like be patient and see what shows up and hope only a few people are looking.
Brent Jesse, the owner of AudioTubes, has said that the two hole version performs identically to the 3 hole version. Looking at the tube construction, they do appear identical except for the holes in the plates. Thoughts?
