The ECC35 is equivalent to a 6SL7, a higher gain tube than the 6SN7.
It is compatible with my WA22 but you should check compatibility with your amp.
The Mullard ECC35 is amongst my favourite driver tubes together with Tung Sol BGRP and the Melz 1578.
IMO the Mullard ECC35 and the Tung Sol BGRP are very similar in their sound presentation, i.e, detailed, articulate, engaging and for want of a better word "euphoric".
The Melz has a drier presentation. Bass is a little lighter than the ECC35 and TS, a very detailed and spacious midrange with a precise top end. I imagine the sound more like SS than tube.
I've given up trying to decide which one I like best. Over the past 4 years I've chopped and changed between these driver tubes. They are all great tubes.
This months favourite is the Melz but I know in a month or so I will be drawn back to the ECC35 or TSrp. That's the beauty of owning a tube amp.
I use the above tubes with WE422 rectifier and either TS 5998 or GEC 6AS7G power tubes.
