dan_can
- Jun 14, 2005
@HiFiGuy528 How is the DAC section of TA-ZH1ES compared to HAP-Z1ES?
Sometime ago, I was evaluating 2 products mainly Chord Hugo 2 or Sony TA-ZH1ES to purchase basing on SQ and value for money for their Pcba design and components. Since Hugo 2 is not available on the market, and Hugo is used in comparison . The prices on both Hugo 2 and Sony TA ZH1ES is almost close to each other. Guess which products is value for money?
You should check your software. There should be no problem playing through via USB nowThe DAC section compare between TA-ZH1ES and HAP-Z1ES is TA-ZH1ES better than HAP-Z1ES. FYI, HAP-Z1ES doens't support USB audio output support last time but Sony launched new firmware to add this function after TA-ZH1ES launched. This means Sony very confident to their signature TA-ZH1ES.
TSAVJason
Stay updated on The Source AV at their sponsor profile on Head-Fi.
Sony TA ZH1ES have many custom IC and Looking at the complexity of their design... It is worth more than the current market prices.
Ok - here is a question for TA owners
I think it is pretty much acknowledged that the SE output is not as powerful or as good as the Balanced output.
I have yet to purchase balanced cables for my Utopia however I do want to test out the TA. I will need to test using its SE output. The device I currently use is a Mojo - obviously also run SE.
I hope that I will be able to see the TA able to show its superiority over the Mojo - even in SE mode??? I am going to hope that it is easily BETTER than the Mojo??
One last question - I am going to assume the Balanced out on the TA is of the same quality level from both the XLR and Sony 4.4mm ports???
