nc8000
No idea what any of those words mean. But yeah, I definitely prefer the Sennheiser's sound over the Sony's, regardless of what acronyms are stuffed inside either one.
And that’s really all that matters. Enjoy
Sennheiser HDV 820 arrived today. Sorry to all the Sony fans, but the sound quality is better for the music I listen to. The low end is punchier and snappier. Drums have authority. In comparison I can see how people say the Sony has a soft and warm vibe. The Sony has more features, but I gotta go with what sounds better for my setup.
Hi! In your opinion, in the end, which is better, the Sony TA or the RME ADI-2? thank you! Because I'm thinking of buying one of these 2 dacs.In comparison to the TA definitely in every direction (more focused to the width). But that does not mean the ADI has a small Soundstage. It is more like my Hugo 2 in that regard.
Thank you for the fast responseThe RME seems to be lightyears ahead of the Sony as far as a pure DAC goes. You've got way more control and functionality with the RME. That said, you'll probably spend a lot of time tweaking and messing with all the infinite settings.
There are many things to compare and lots of differences in terms of usability, tuning ins and outs etc... For that just take what you need.
Soundwise I will just comment the differences not the individual qualities:
RMEs ADI is cleaner, more open (from mids to highs) and dynamic sounding from the internal headphone amp. That is why I use it for mastering.
The Sony on the other hand has more focus from the lows to mids. Soundstage is also bigger in width, depth and hight on the TA. That is also the reason why I prefer the Sony for private/fun listening.
These often used terms would typically describe them:
RME is more on the analytical side (compared to Sony; there are still way more analytical sounding ones out there).
Sony is more on the laidback side (not only compared to the RME; it kind of sounds more analogue).
I hope this kind a helps
Ok thanks!Don't listen to this guy, he does not know what he's talking about.
He was saying the other day in the empyrean thread that he couldn't hear the difference between a laptop sub 5 dollar/unit dac chip and a dragonfly cobalt.
Please be careful on the forums.
Well, instead of giving a thoughtful response like Hellraiser86 did, which actually explained the differences in sound, you said something that was kind of not really true, and in any event wasn't particularly helpful.
