Both DAC/AMPs are not the best solution for this task (I know the Oppo has more power but it isn’t enough for such a demanding can) If driving this headphone is your prior intention, then spend the money in a dedicated headphone amplifier like a Violectric HPA-V281 or something in that class (don’t know the price you can get the TA but in Germany it’s about the same price as the Violectric).
The Oppo has 2.000mw at 32 Ohm and the Sony 2.400mw. Sorry I just remembered the single output from the Sony homepage which was 1.200 (and forgot the + sign )
But 400mw are still not much for a HE-6
Yes this is what i thought too, it is nice to have that extra 400mw but yes it might struggle to make the HE-6 sound right. they do sound okay out of my Oppo but it's pretty much at max on the volume dial on high gain with very little headroom left. I suppose the Sony would be better but just.
If you like the more bright sound (in comparison to TA) just upgrade the Amp. A Cayin iHA-6 has definitely the power to drive them and has a great price tag (but on the other hand there are some people who claim you need a speaker amp)
The reason i'm considering the TA is because i don't like the bright and clinical sound of the Oppo too much. I heard the TA is much warmer which is why i am considering
In that case the TA is quite on the other end of the spectrum. So maybe it could sound a bit too relaxed for you (that’s just something to consider). Don’t know your budget but Hugo 2 would be a good option too
I see that you’re using the AQ jitterbug with your TA. Did you notice much of a difference with it? I currently have AQ carbon cable from my TA direct to my PC and considering adding in a jitterbug.
Ended up ordening this Sony. I was overthinking about measurements and al the things that comes around ( i was also considering the Matrix Sabre Pro and the Rme Adi-2 because of their specs ). But, in the end I decided to buy the Sony because of its focus on the lower spectrum ( My ears are very sensitive to the highs ) and because I’ve found it on Amazon on sale ( not too much, but stil 5% less than usual retail price ). I’ll share my impression when it arrives!
Many thanks to hellraiser86 for his comparison!
It depends on the source I am using. For example if I connect it with my MacBook Pro I definitely hear an improvement (really funny considering that I didn’t believe in such things before^^). If I am using my iPad Pro the difference is not that noticeable.
i have bought both the aq jitterbug and the ifi usb purifier during a moment of weakness (you know... audiophilia nervosa).
i left the jitterbug in my system because it doesn't hurt to have it in there.
but in all honesty... i can't claim that i am able to hear any difference.
and i don't think this is because my hearing is impaired, i definitely can hear differences when swapping headphone cables and analog interconnects for instance. but differences in usb cabling and usb purification on the tazzy...different story imo.
a thing to consider: sony has gone to great lengths when it comes to jitter rejection on their s-master products. (in previous iterations of their s-master architecture they called this their "clean data cycle" which sports an attosecond clock for re-clocking the signal.) the tazzy is built around the s-master hx architecture and a chassis that is supposed to suppress physical interference with the internal timing of the clock through vibration.
so, i believe jitter is not an issue. what other reasons could there be to add usb purification? introduction of noise to the system? i can't hear any improvement in that department either.
i don't think that money spent on usb purification is money spent well. just my humble opinion.
