Soundizer
- Dec 29, 2015
I can reccomend the ADI-2 if you want a clean sound. The Soundstage is also a bit narrower.
The Soundstage is narrower on the ADI-2?
In comparison to the TA definitely in every direction (more focused to the width). But that does not mean the ADI has a small Soundstage. It is more like my Hugo 2 in that regard.The Soundstage is narrower on the ADI-2?
Would I be able to use the WM1A as a USB source for the ADI-2? Or is that just a Sony TA-ZH1ES feature?In comparison to the TA definitely in every direction (more focused to the width). But that does not mean the ADI has a small Soundstage. It is more like my Hugo 2 in that regard.
Sweet. ThanksIt should work as a usb source for any usb dac
Considering the TA-ZH1ES but mainly as a DAC using the PRE OUT to an Integrated Amp. Does the TA-ZH1ES perform well as a DAC in that scenario? I'm interested in its ability to upsample to DSD, but not if it's either compromised as a DAC or in the PRE OUT section.
That is a tough one because I use the ADI just for mastering work and the TA is for my fun listening. To come to a conclusion, if both were for my music listening system I would stick with the TA (I do not need eq or all the extras) just for sound. It depends though which headphones you are using. For example I have got the Sony MDR-Z1R and they sound brilliant with the TA but do loose some fun with the ADI. But this is completely different with my Audeze LCD-X (my mastering headphones) which do sound a bit muddy with the it. But to be fair the most of my headphones sound awesome with the TA (just some of them with the ADI).I think you are a good person to ask since you have both.
If you had to keep only one which would it be - TA or AFI?
Is this on the Walkman micro USB or the PC USB-B?I've noticed a couple of interesting things about this unit along the way. It looks like Sony has cooked up their own USB receiver setup using a TI chip. I gather they have done it to be able to receive DSD512 in the manner they want to without conversion. Their setup does use the +5V from the USB and it is by far the device most susceptible to presenting USB issues that I have ever listened to. Cleaning up the USB connection made a big difference in imaging and detail for me and has made a good unit into a great one. I now have it connected to a motherboard that allows me to disable the +5V on the USB connection, and then I have it going through an old iUSB 2.0 that provides an isolated +5. A split cable and a battery works well too so not an expensive tweak.
The sound is just fabulous like this, liquid silky and detailed. I've compared the Sony to a lot of other units over the past year and while there have been some setups that I have thought sounded fun it's the Sony that has remained on my desk.
Headphones like the Z1R, LCD-X, Sennheiser 660S or Utopias are no problem at all. Even the unballanced connection has more than enough power. You ll probably never reach more than 70% with it (for example I can not listen above 50%)Thank you for the Clear explanation which makes me think I should get another TA. just need to save up a bit for it.
Does the TA have enough power to drive the Z1R via the quarter inch input/6.35mm?
Thank you. What is the brand for S8 Subwoofer and is it connected to A5+ or directly to your TA? Thank you.I have the Audioengine A5+ powered and S8 Subwoofer connected to the TA in my office, works great.
