Hahahahaha maybe not! There is another solution I personally use. I bought a set of Sennheiser TR175. Works great, sounds good and keeps the spousal unit from screaming at me to “Turn that crap down!!” I think in the UK they’re about £130.
I'm using my TA-ZH1ES with my TV using optical connection and it works fine - but you'll need to make sure your TV does the conversion to PCM as many channels use dolby digital / ac-3. The TA-ZH1ES obviously doesn't decode this.
Also consider Questyle CMA400i or 600i which pair well with LCDC 2C. The CMA400i is black which is a nice cosmetic match. Get a balanced cable 4pin XLR.
I don't own the Hugo 2 so I don't know but I tried out the 600i before and it was good but not a great sounding desktop amp/DAC unit. I would classify the TA-ZH1ES to be a great sounding. All relative to your benchmark obviously and the pairing.
Jason is a great guy so he will tell you straight but you may still want to audition them yourself because everyone has their own preference. Jason is an Utopia kind of guy.
