Soundizer
- Dec 29, 2015
AudioQuest is good and we are a dealer for their products. I’d say there are better choices but sadly 1meter USB cables that really work well are in the $400 -$500 price range. I personally went Kimber Axios but it is far more expensive. It wouldn’t be a cost effective buy in your rig. I would suggest looking at the Nordost Heimdal 2 USB or the Kimber KS2416 or better both can be had for under $500. Both are 3.0 verified and certified ...... still not cheap but they both would make a significant improvement. You’re welcome to send Alan@thesourceav.com an email to see if we have any special deals on any of them. If you have a local store carrying these products see if you can get a loaner deal happening to be able to audition them.
Hi Jason,
May I ask what Gain setting you recommend [LOW] or [HIGH] when driving Sony MDRZ1R and Focal Clear?
Many thanks.
I adjust assumed LOW Gain is for IEM’s so have only been using HIGH. However after changing to Low I notice a slightly less sharp sound.
