No normal DAC inside again. I guess this is again 15 + 15 mW, no?
4.4 mm balanced output - what is this?
Why not standard 2.5 mm?
Hope it sounds good...
2.5mm was an Iriver standard, 4.4mm is the official JEITA (Japanese version of DIN/ISO) standard as of this April.
Newly announced Onkyo and Pioneer DAPs are also migrating to 4.4mm no 2.5 or dual 3.5mm
Regarding balanced audio connectors: I'd like to see the industry agree on a single standard, and I'm quite strongly inclined right now to support Pentaconn as that standard. I've been using Pentaconn with the Walkman NW-WM1Z for a few days (with the Sony MDR-Z1R and its included Pentaconn cable), and it's immediately apparent how much more durable and secure this plug / jack configuration feels, versus 2.5mm (which I have
never been a fan of as a connector).
If you look at most 2.5mm plug implementations prior to its use as a portable balanced audio connector, you'll see they were usually on the ear side of a headphone cable, with the strain relieved by a coupling between the plug body and the receiving housing--not directly on the 2.5mm pin. However, since its adoption as a balanced audio connector, the jack sits flush, giving no support or strain relief to the 2.5mm plug--so the tiny plug itself bears the force of any strain. While I'm careful with these connections (knowing how delicate that 2.5mm plug and jack can be), I've found the connection almost always feels loose, due to its shallow insertion and tiny contact surface area--it pops out way too easily, sometimes just enough to mess up the connection, and often all the way out.
Before Pentaconn, I recommended to at least a few portable device manufacturers to reconsider their use of 2.5mm, and instead go to mini-XLR, or some such. Now that Pentaconn is here, though, and having used it, I think it's the way to go. I know of other manufacturers (in addition to Sony) that will be supporting Pentaconn in upcoming products. As mentioned by
@deafdoorknob, JEITA (Japan Electronics and Information Technology Industries Association) saw fit to make Pentaconn a standard, and I'd like to see the personal audio industry follow suit.
(Above, left to right) Pentaconn 5-pole 4.4mm plug, 6.35mm (1/4") plug, 3.5mm plug.
