A few words on the new A6t, which turned out to be something I instantly liked. For starters, the A6t shares a strong 'house sound' with the A4t and A18t, which can can be described as a variation of neutral/natural. The sound is predominantly neutral, but by means of an enhanced mid-bass and upper and lower treble 64 Audio mixes in a dash of warmth and brightness, to make it a more musical variation of neutral. So, if you like the tone of the A18t, you will also like the tone of the A4t and A6t.
The A6t too has an enhanced mid-bass, with a lower treble peak around 7 KHz and bit of upper treble emphasis around 12 KHz I believe. But where it diverges from its siblings, is with a very pleasing midrange, stemming from a nice bump between 500 Hz to 2 Khz. This results in slightly forward, bodied, and sufficiently dense vocal presentation, with just the slightest touch of thickness from the bass. In sum, a very natural vocal reproduction - flinkenick approves. Its bottom extension is around average, but its mid-bass is more than sufficient in quantity, and remains nicely controlled. It's a punchy bass, that adds a musical element, and some extra body to the sound. The treble in turn has a clear tone, but is smoothly integrated within the signature. All in all, an easy-going and coherent signature which simply sounds very good to my ears.
When listening to the A6t, its performance does not feel lacking in a way that disappoints, simply because it is an enjoyable signature. Nevertheless, there is a steady increase in performance between the A4t, A6t, and U12t for instance. The U12t has a noticeably cleaner presentation, besting the A6t in terms of separation, transparency, and resolution, while having a significantly wider stage. The A6t does not quite reach top-tier in performance, but comes close enough. The U12t's performance on the other hand I find slightly above average in the top-tier range.
That being said, the U12t in turn has a very neutral tone - what I personally would describe as dead neutral, although its signature is also very coherent. Even with the M20 module, it has a neutral tone, although the mid-bass is more evenly balanced within the signature as a whole. The increase in performance between the models is partially due to the quantity of bass, with gradually decreases from the A4t, to A6t, and U12t, which affects the airiness, separation, and transparency - as well as the tone. For while the U12t is clearly technically superior, the A6t to me has the more beautiful tonality, and is overall very reminiscent of the EarSonics' EM10 at a cheaper price, or a less warm Phantom perhaps. For people that want to stay within the 64 product line, I think the A6t would be an excellent companion to more technical iems as the U12t, U18t, or Fourte, offering a more easy-going and natural signature for example vocal-based music. All in all, I think this is a very nice upper mid-tier model that I would have no problem listening to on end.
