The pelican 1020 holds the Mojo, A12t and the other little cables great! The inside is a soft rubber material and it holds the Mojo perfectly in place so it won’t bounce around. Very happy with this purchase. I also bought the FiiO HB1 but it will only hold the IEMs. But it’s smaller and I prefer it to the 64 audio case. They were cheap enough that I’ll keep both.
He probably ordered through Music Sanctuary. They do have a website you can order stuff and get it shipped to you. https://music-sanctuary.com/
^their website
Thanks, yes MS does ship to Taiwan and that's also what the local HSA salesperson told me to do if I want to get the RedCore.
I am waiting for HSA to release the 8-wire version of Aegis in a few months. Then, I'll likely audition the Aegis 4-wire & 8-wire using A18t and see if I like either one. If not, I'll probably go for the RedCore.
I've tried it, it basically has similar characteristics to: plussound tricopper, effect audio lionheart. It has a warmish sound with rounded bass and relatively relaxed treble
Which IEM did you try the Aegis with? I've seen many Aegis reviews with Vision Ear IEMs and one thing reviewers consistently rave about is its vocal performance. I can't wait to get my A18t and try this pairing.
Nope Univeral...
I'm not sure yet about Custom Even if it's really tempting!
Maybe next time I'll by some IEM they will be Custom. But I need to find the perfect one first...
Nope Univeral...
Nope Univeral...
Hey LaCap!
I have sent you a PM. We have a large amount of orders going out today and tomorrow and I want to ensure you are apart of that shipment.
Thanks!
Rock
