Cause I can't post it publically. Plus this is a form for IEM's not apps. You don't have to, search the web for the full version. You will likely find what I found. Search for JetAudio Full .apk.
The new IEM of Vsonic VSD 3S ( impression updated by smailbz)
- Thread starter Cy514
StoneColdSooie
- Sep 10, 2014
Or instead of side loading the app you could buy it and support the creator of the app you so highly recommend.
StoneColdSooie
- Sep 10, 2014
Link:https://www.google.com/url?sa=t&source=web&rct=j&url=https://play.google.com/store/apps/details%3Fid%3Dcom.jetappfactory.jetaudioplus%26hl%3Den%26referrer%3Dutm_source%253Dgoogle%2526utm_medium%253Dorganic%2526utm_term%253Djetaudio%26pcampaignid%3DAPPU_1_NvnUVufPEYSMjwO5v53YAw&ved=0ahUKEwjnwrK9s57LAhUExmMKHblfBzsQ8oQBCCEwAQ&usg=AFQjCNHmn3AAPtqvmXC6jVM877oHth3VDQ&sig2=2bICiC-Sbv1cOJgUK9331A
You can try the trial version and if like it buy it sure.
squallkiercosa
- Apr 8, 2012
Hey everyone, I got a faulty cable, I wanted to solder but I cannot figure out which one is which (there are 4 cables plus the ground) have any of you been able to fix by yourself the cable? Thanks
Shawn71
- Aug 18, 2013
4+1 wire?....is it a after market cable with mic/remote or the stock? I guess you have the removable cable version from the first batch.
Pls post a picture if you can.
squallkiercosa
- Apr 8, 2012
This is the cable, I dont even know if the copper cable around is just decoration...
Shawn71
- Aug 18, 2013
Ok fair enough,you can check the continuity between the cut ends of those five wires and the jack end......Its the copper wire (not enameled) is the common ground(grnd for both L & R) and 2 each of remaining 4 wires are used for L + & R+.
fredhubbard2
- Jun 18, 2015
Just ordered a pair of the upgraded vsd3s' . I own vsd1s and havi b3 pro1's which I love so really looking forward to comparing them .
I think the Havi's have it. LOL
Anything around a cable on the outside is never a decoration. It will always either be insulation, a active signal line, ground or shielding, or protection for the inner wiring core.
DanMar
- Nov 8, 2014
As I remember, maybe 90% correct...
helllooooooo
- Sep 1, 2013
yo are there any reviews out there for the new updated VSD3S??
Sure, Here is my quick dirty review. "Sibilant" so they go back in the box and under the bed. Next!!!
helllooooooo
- Sep 1, 2013
Is it that bad? The sound is different from the originals? I have the originals and they sound really good after several hours of burn in
