willy156
- Nov 18, 2013
I still use my original VSD3S detachable ver. back from July with no problems
So after much thought , I've decided not to take a chance with the vsd3 , gr07 was too much of a disappointing experience to ignore and there are a worrying amount of vsd3 with cable/housing issues . Have a buyer for them and decided to go with a different brand . Thank you all for your help .
You got the GR07 Classic Edition? Why it was a disappointing experience for you?
guys Im considering to buy VSD3S, but which one should I buy? The non detachable version or the detachable version? Both got silver plated cable..
For me build quality issue is very important though, since I want this IEM to last long and Im a pretty clumsy guy.... (although sound quality is also very important factor to me)
Thank you for your answer guys!
If you want a durable headphone, I wouldn't even consider the VSD3S. The undetachable version might not have connection issues, but it's still the same poor quality cable.
ouch! Is that true?So should I buy ATH IM50? My music preference is classical music, which one do you think is better for classical music?
Do you really think it will be easy for the cable to be broken? Is the durability of VSD3S really really bad? Actually I can sacrifice durability (if it is still tolerable) and try to be very careful in taking care of the IEM if the sound quality is really better than ATH IM50.
