The Mini³ v2 is out!
Jun 7, 2007 at 3:57 AM Post #16 of 50
I think it was made using eagle CAD software which is made for circuit boards if i am not mistaken or somebody made it in a 3d design program
Jun 7, 2007 at 4:36 AM Post #17 of 50
Originally Posted by tomb /img/forum/go_quote.gif
Boy, I hope that doesn't mean 47 more iterations. You look a lot closer than that.
I am definitely closer than 47 more revs.
I gave myself plenty of "room" so I won't run out of numbers, but I don't expect the circuit and layout to change that much.
Originally Posted by Joshatdot
How do you make a 3D model of the board like that?
It's done with Eagle3D, a third-party add-on software for Eagle that generates a ray tracing file from the .brd file, and then the Povray program is used to render the image.
Jun 7, 2007 at 10:24 AM Post #19 of 50
Originally Posted by DaKi][er /img/forum/go_quote.gif
http://www.matwei.de/doku.php?id=en:eagle3d:eagle3d
Sweet! Thanks guys, now I got a Render of my CMoy board
Jun 7, 2007 at 1:10 PM Post #20 of 50
This looks like another awesome project. Thanks!
Jun 7, 2007 at 11:24 PM Post #22 of 50
I have to ask about the LED's. I see that they are board mounted and near the edge of the board. I assume that you drill a hole in the end panels of the case so that the LED can be seen when lit. Because the LED is facing up and the hole will give a view of the side, will this look normal? Normally, LED's are viewed from the top. Or is my understanding of this package wrong? I didn't think that the top of the enclosure would have the viewing hole because the LED is so far recessed from the top.
A clear plexiglass or lexan cover would be nice (or a clear case).
Jun 8, 2007 at 12:13 AM Post #23 of 50
bend the legs of the led 90 degrees so that the led faces out of a drilled hole in the faceplate??
thats how i've done all my leds ... apart from my soha where the led is underneath the tube.
edit: and my pimeta ... as the case is translucent anyways
Jun 8, 2007 at 12:56 AM Post #24 of 50
I should have mentioned that. If that was the idea, then I would have expected the rendering to show that way.
I'd like a translucent case for this!
Jun 8, 2007 at 1:15 AM Post #25 of 50
That is the idea, but the rendering doesn't show it that way because the standard Eagle library LED part doesn't have bent pins.
Sorry, not in a Hammond 1455 series anyway...
Jun 8, 2007 at 1:51 AM Post #26 of 50
Thanks for the answer.
I won't worry about the case, just want a descent DIY amp.
Jul 11, 2007 at 9:48 AM Post #27 of 50
More pics here.
As you can see, a lot of progress has been made since the previous post in this thread.
Please see the Mini³ v2 project thread for updates. Everything is moving smoothly to a projected release before the end of this month.
Jul 12, 2007 at 1:10 PM Post #30 of 50
Originally Posted by kim1 /img/forum/go_quote.gif
Well done AMB, though, well, perhaps a whole new project with opamp + discrete buffer would've been even better at this point. Just my opinion!
Better than a DIY portable of this size? (Note: that's a credit card!)
You must be joking. A discrete buffer sounds great, but at this size? NOT!
