philodox
- Dec 12, 2003
It can drive the K340's to levels which would likely damage your hearing. Seems to be supplying more than enough current and voltage swing for them. I'm not noticing any of the issues that arise from them being underdriven.
It seems to have enough oomph as far as I'm concerned, but could use a bit more extension I think. I'll have to try some test tracks to be sure about this.
Originally Posted by swt61 Without going into too much detail about the sound yet, can you tell us more about the power this amp has, and if you're sufficiently sattisfied that you're driving the 340's to the point you desired? |
Originally Posted by GlendaleViper Jay, has a night of burn-in opened the low-end up at all? |
