Skylab
Reviewerus Prolificus
Lowering the volume in FOOBAR will reduce resolution, so you don't want to do that. But I am always able to find a step that works for me on the Leben.
Yes, MUCH better than the Extreme.
I put in the lower-gain 5751 driver tubes, and now I use the volume control about 9:00 - still a bit low, but it's not an issue for actual usage.
Skylab said:
I have a very slight buzz on my most sensitive headphones. Can't hear it at all with my LCD-2, Ed 8, HE-5LE, D7000, or T1. Very slight with W1000X. More noticeable with the DX1000, but the DX1000 has revealed very small noises of lots of amps that I couldn't hear any noise with any other headphones.
And to be clear - all of the above is with NO music playing - can't hear it at ALL with music playing, with any headphones.
I bet I could get rid of it with tube rolling, though. But I like the sound of the tubes I have in there, and it doesn't buzz at all with the LCD-2 or Ed 8, which are mostly what I use with it.
Henmyr said:
I do not hear any buzz with any of my phones.My W5000 are very sensitive and hisses a lot with the CTH but is completely silent with the CS300.
As for volume, sure, it's not much on the dial, but I can adjust the volume perfectly all the way down to zero without channel imbalance even with the very sensitive W5000, so I have no problem with it.
I'm thinking about pulling the trigger on the CS300xs. I got a quote from PriceJapan at $2,427.
I am planning on using this with my Lavry DA10 and HD800.
arnesto said:
The 120v version can be had if you buy it from the US distributor, but you will end up paying $3,500 for it.
I will buy a convertor for $17.99 from that voltage convertor website mentioned earlier on this tread.
Thanks guys, I just needed that extra push.
Life is short. DO IT!
After having owned and lived with the Leben CS300XS for a time, if I had to do it all over again and pay $3500.00 for the experience, I would. It's a genuine bargain from Price Japan, add the converter and it's still a steal.
It's sound property, mated with a worthy source, is that of actual. Nothing in it's nature is contrived or forced using the Audez'e! Makes other amps (some very good one's) sound mechanical and antiseptic (transistor), or slow and lethargic (triodes and OTL's). Sounds like flesh on bone! The final arbitrator of the sound quality is left in the lap of the Source Material, where it belong's....
This is how im feeling about the Stacker II right now, will be interesting to compare it to the Leben.
