New N8ii Owner!
Going past first 20hours of burn in, and wanted to share some of my opinions/observations.
I might be in the minority here and don't want to pass final judgement until I get at least 120+ hours of burn in, but my initial listen to set an initial baseline (Med Gain, P, Tubes, Class A so far my favorite), while there were some great micro details, my Lotoo PAW6K in true LO into the Cayin C9 ( in Low gain, Tubes, Class A, pre in) just sounds more musical, and fuller.
Not getting the same euphoria others have experienced with their initial listens on the N8ii.
I'm hoping that getting burn in completed will remedy this.
Again reserving final judgement until I get burn in done, can choose the right app and do some additional tuning (one of the things great about Android, the flexibility, but its also a curse). Will post final thoughts and HOPEFULLY not that the N8ii is up for sale once I've had some time with it after burn in.
My initial listen and from previous experience with Android DAPs I also tried Neutron, Power Amp, but did not have a chance to try UAPP, as many here are using.
Power Amp is a hard pass, and Neutron I will have to futz with as it never came off of 44.1khz even on FLAC test files I have that are 192khz, but looking like a pass also. Will try UAPP trial version after burn in.
Had a lot of back and forth on the Cayin Music Player, but it is finally sorting like I want. (again something I'm not fond of is the way Android Apps sort by default.)
The Cayin Music player has decent sound, but once burn in is complete will sit down to the task of choosing a player and really tuning it. (As well as items big and small to personal tastes, one example is the Lock Screen clock to be 12 hr instead of 24 hr clock. Figured out for the main clock, not the Lock Screen clock so far, something to do after burn in….Too many settings to go through?)
A curse or blessing with Android?
FW updated to 1.3 without any issues, and the battery readings are not only looking accurate but the battery settings are cycling as they should (have max battery set to 95%, and once it reaches there it discharges to about 70% then starts charging back to 95% and then repeats)
One of the things I do miss from my Lotoo DAPs with its OS, is the speed. While the N8ii is good as far as other Android DAPs I've owned, the Lotoo DAPs (PAW6K and LPGT) really do boot and shut down fast and are really snappy in response, maybe not as flexible as Android, but miss the speed none the less.
Their player also has a nice sound signature to it, hoping I can tune the N8ii to beat it, but as MVVRaz has already posted, he did not see a substantial improvement over the Lotoo DAPs, and specifically the PAW6K, my current DAP of choice, especially when combined with the Cayin C9.
Thanks to Twister6 and his comments earlier about chargers he’s tried.
The Anker model 711 30w Charger is working great during burn in.
Allows the device to play and go though the charge/discharge cycle without overheating, and its fast charging to slow charge cycling also.
Bonus is its size and it runs cool for a GaaN charger.
Also I've added a nice heatsink I found on Amazon that fits the N8ii perfectly
With the charger and the heatsink, even in Tubes/P/AB mode being used for burn in cycle (thank you Andy Kong for your recommendations in this thread for burn in settings) the device (and heatsink) is just barely warm to the touch, so I have confidence I can run it the next few days continuously and get burn in completed, without triggering the overheat protection
If anyone is interested this is the Heatsink I found on Amazon, and pictures of the N8ii on it are attached to this post
Was about $12 and available in several colors (150 mm x 85 mm x 12 mm/ 5.9 x 3.35 x 0.47 inch (L*W*T)
https://www.amazon.com/gp/product/B089QHMG5M/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Just want to thank all who have posted here for all of the information!
Nothing but the utmost respect for all I follow here and keeping fingers crossed I will enjoy as much as you all have.
Appreciate all the comments from everyone In this forum, both positive and not so for the N8ii, that have been posted, as they helped me decide to pull the trigger and take the chance.
Just wanted to give back to others who may be looking to move to the N8ii, and are on the fence one way or the other.
And of course all I have posted above is IMO, and YMMV
