Akira1977
Won't be much of a point if it doesn't. Then again, we won't know till it is released and tested.
I have purchased the KZ ZS10 Pro, i just need to decide between the ES100 and the BTR3K. ( or maybe a powered DAC without BT to avoid to spend too much...)
If i want to use one of the two directly connected to the USB port of the phone, what is the maximum quality as DAC? ( 48 kHz/16 bit for both, right? )
What is the power output of the ES100 with 32 Ohm? ( ZS10 are 30 Ohm, but just to compare with the BTR3K)
Thank you!
