greyforest
ok just got a oriolus 1795 i will do a simple comparison here for future reference
Comparison between Es100, up4 , 1795
1795 is not as easy to use as es100 or up4, mainly because of the forward and backward buttons is the same as the volume button, very painful to operate as the volume adjustment is weird as well. Also during my 2 hour of usage the device powered off by some reason.
Sound: up4 sounds very warm and thick, with less detail is presented compared to es100 or 1795. But it is the one most easy to listen to, with zero harshness and quite forgiving for record quality.
Es100 among those three have the best horizontal soundstage and detail revealing, also the transparency wins quite a margin. With an competent app to eq the sound its a bargain and i would call it a low end dap killer.
1795 sounded warm with oriolus sound signatures(unique female vocal), slightly less detailed as es100 , narrower horizontal soundstage but with noticeable better vertical and frontal depth. There is some noises if you are using sensitive item or pushing the power to the maximum level. Overall it remains in the same league as es100, but noticeably less transparent compare to es100. I know there are people don’t care about transparency and would definitely consider 1795 to have better sound compare to es100. Besides all that The imaging is lager compare to es100, with an emphasis on low end.
Despite the larger size 1795 have less power than es100 with less battery time and longer charging time as well. (Yep the typec and wireless charging is completely useless because it only have 5w capability)
also tested usb-dac function of 1795, i would say it is better than the es100(usb-dac mode) with the soundstage widened imaging is improved as well.
So as conclusion I recommend es100 as the overall experience is much better than the others, if you only enjoy classical or jazz es100 is the best choice among the three. Up4 have a volume nob which is something the next gen es100 or q5k should definitely consider to add on. I only recommend anyone who have the need for a semi decent usb dac to get 1795 as the wireless experience is some what forgettable. Or you have a real passion for female vocal music with a iem that is dedicated for that as well.
The headphone i used for this test is final a8000 and audioquest nightowl.
