devhen
- May 16, 2012
Generally leather/pleather pads increase bass quantity and impact.
Not necessarily. See for example the closed back DT 880 thread, were the common opinion is that leather pads brightens up the sound and gives lesser bass impact than the velour pads.
And some bass heavy headphones with velour cushions: Pro900, DT770/80 pro, HD 650....
Originally Posted by Marleybob217 /img/forum/go_quote.gif
soon I'll get the J$ pads and I think these will work much better.
Well, this will be interesting...
Has anyone noticed the driver/cable imbalance in these headphones? I've noticed that the right driver is a couple of db's softer than the left driver, and it is quite noticable.
This is probably due to the cable connecting to the left driver first, and then going to the right driver. I've actually noticed this with all single cabled headphones. I did replace the cable, but it has been there with the original cable. I just wasn't this annoyed by it.
I might actually drill a hole in the right ear cup and attach the cable directly to it....
Are you going to split your microphone cable or get a new one?
BTW, I've tried the DT-770 pads. I didn't do back-to-back listening yet, but off the cuff it seems they're not as punchy as the oval pads. That said, they're comfy as hell. Seems like the problem with the oval pads is not the surface area pressed against your head but the sheer rigidness of pleather.
So... I don't know. Might try taking to needle next, especially since i've cut off and old pleather headband and started prototyping the new one.
Man, you are playing with fireWell played btw, great job. You are happy with the results too, that's the most important part.
Can someone suggest me pads? I am not so happy with the stock ones and looking for something more comfortable. Beyer pads probably would solve it but still wanted to ask.
Great job on the balanced drivers. Btw I'm not sure if the ground cable is needed.
