theaudiologist
apparently yes, it's 32 bit floating point PCM
are people really selling 32bit records? I can understand having 32bit ability in a DAW to get ever more headroom for some reason, but I don't know of an ADC capable of resolving 32bit(and for which purpose? listen to ants in the wall 2 rooms apart? and then of course there is that other small detail, no sound system can output even 24 bit resolution to this day, let alone 32bit.
so why would music be exported to 32bit?
Come on, you already know the reason. More bits sell for more bucks. Simple math.
Just out of curiosity: Does anybody know how to calculate the dynamic range of 32 bit floating point PCM? I'm sure it makes a huge difference, maybe even a measurable one. Too bad we human beings can't hear it. We can still see and compare the numbers, though, and we tend to take numbers very seriously. Today many smartphones have a 64 bit architecture. When will we see 64 bit audio files?
http://diwaves.com/tmp/sample_bits.htm
Very interesting! So floating point has no dynamic range advantage over integer. Why is it used then?
Unlike with integers, and because the mantissa is normalized, the quantization error is not fixed. It is relative to each sample value. This has important advantages over integers:
1)The effective resolution for every sample is the full resolution that the mantissa allows, while the effective resolution of an equivalent size integer corresponds only to the significant bits used by the actual value.
2)The SNR is constant regardless of the signal level.
3)The quantization noise is relative to each sample value. For any sample value smaller than 0 dB, the quantization noise is also smaller by the same ratio.
4)Even if a signal is normalized so its peaks are 0 dB, samples that are not peaks, but smaller values, exhibit a smaller quantization noise, always a fixed amount relative to the value itself. So while the maximum error in this case is the same (for the 0 dB values), the average is smaller (every other value has smaller error). Note also that our ear is more sensitive to distortion and noise in the parts of the waveform closer to zero, and less in the peaks. More exactly is more sensitive to the differential or slope, which is highest near zero and minimal at the peaks for a sine wave, and statistically similar for any signal.
Do you want to discuss the sound science of bit-perfect playback?
I have a weird issue and I'm not sure what is causing it so any help would be appreciated. I have a 1 TB hard drive connected to my Asus router. I copy a foobar folder over to it and it's fine for a while. Then usually within a week I open foobar2000 and my library is gone. Look on the hard drive and the foobar folder is gone. This has been going on now for about 6 weeks. Any ideas?
Did you set a static IP address for the storage?
...why does Foobar2000 allow for volume control with DACS that have own (HW) volume controls? I use Foobar2000 on my Windows-based Notebooks and UAPP on my Android-based Smartphone. UAPP is able to determine which of my DACs have HW volume controls (ex. Mojo) and which do not (ex. AQ Dragonfly)...
One more for the list; why is it that with WASAPI one has to select the Bit-depth? Again, I would expect Foobar to set the bit-depth based on the source...![]()
ASIO does not have this option but I'm not quite happy with the sonic signature and prefer to use WASAPI.
...In practice if your DAC supports 24-bit then set it to 24, otherwise 16. No adverse effects with playing 16-bit files through 24-bit interface.
