Thank you so much guys for detailed replys..
My Marantz CD-6004 CDP also use CS4398 DAC and sounds very delicate so,
I think I would go for x3ii first and see how does it sound without ex amp. Just few other questions sorry
Due to the lack of an internal mem I'm not abale to get sound out of the box with x3ii right? So if I get a micro sd, should i download my music directly to the x3ii via usb like many other DAPs or every time I shoud take that card out and use a SD reader?
I also wondered if the EQ circuit is digital or analog(before DAC or after?)! Cause I hate those noise and crackling/hissing caused by digital EQs found on smartphone for exp.
And, before going to shop anything especial should be concerned to aviod getting a lemon or used one? I'm going to pick it up from a store.
Thanks in advance
What I did was: The first time I loaded my music library onto the micro-SD, I did it by using the SD-card-sized adapter to insert the Micro-SD directly into my laptop, because the data-transfer speed that way is much faster than when it is inside the X3ii, which limits it to about 5MB/s transfer speed. However, whenever I have SUBSEQUENTLY put MORE music onto the card, or deleted things from it, I do it by keeping the card in the player and putting the player in storage-mode. Why, you may ask? Well, it seems to me that constantly inserting and removing the micro-SD into the slot in the X3ii probably can't be good for the card, and may cause it to have a shortened lifespan as a result! I don't want to risk that. Since now I only ever put maybe a gigabyte or two of stuff onto there at any given time (as opposed to the over 100 gigs I had to load onto teh card when I first transferred my whole library) I don't really mind the slower 5MB/s speed.
Keep in mind that before you transfer anything to the card, you will want to insert the card once into the X3ii and use teh X3ii to format the card into Fat32 and with the optimal sector/block-size for use with the device.
Anyway I'm pretty sure the EQ is digital, but, it doesn't create any crackling or hissing as it is implemented very well. It isn't volume-matched with the non-EQ setting, though, so if you want to do a side-by-side comparison and get a good picture of the changes, you'll have to make one of the custom presets set to all-zero and switch back and forth between that and the other settings to your comparisons.
I haven't heard of many cases of people getting lemons/defective units of the X3ii. It does happen, but that is true of ANY electronic commodity, not just this one. Luckily, Fiio has very, VERY superb warranty coverage and super-attentive customer-service, so if your product turns out to be defective and god-forbid the store you bought it from won't accept a return/exchange, Fiio will surely repair or replace it for you.
Yeah I do very much like the sound of the CS4398 DAC chip. "Delicate" is how I would describe it as well. Very good detail, somewhat analytical sounding. Some people prefer a less analytical, more "organic" sound, but since I am using the device with smoother, somewhat colored and more organic sounding headphones (the Sony MDR-1A) I find it to create a perfect, complementary pairing, as a result. I'd say that the X3ii makes an IDEAL pair with the MDR-1A as a portable setup, as far as my own sonic preferences go. This is the happiest I've ever been, so far in my life, with my music-listening experience
I guess what I'm saying really, getting back on-topic, is that if you pair the X3ii with smoother, more organic (not super-analytical, but still good with detail) headphones, it will create a very nice "balance" between an analytical sound and a smoothed-out sound. While, if you yourself want a super-duper-analytical sound, then you can pair the X3ii with something like the Audio Technica ATH-MSR7 and that is what you will get! :-D
