The FiiO X3 2nd gen (ex X3K, X3II) Thread : 192K/24B, CS4398,Native DSD, USB DAC with LO and inline remote
May 9, 2015 at 2:13 PM Post #3,316 of 9,972
Can anyone tell me if the following is a suitable micro-sd card for the X3.
SanDisk Ultra 128GB UHS-I/Class 10 Micro SDXC Memory Card Up To 48MB/s With Adapter- SDSDQUAN-128G-G4A [Newest Version]
http://www.microsd.ca/SanDisk-Ultra-128GB-UHSIClass-10-Micro/A/B00M562LF4.htm
Thanks
May 9, 2015 at 2:15 PM Post #3,317 of 9,972
Thanks
Yes, it's the one I use and have had no issues with it.
May 9, 2015 at 4:02 PM Post #3,320 of 9,972
Thanks
That's probably the best microsd card money can buy.
May 9, 2015 at 4:58 PM Post #3,321 of 9,972
http://www.sandisk.com/products/memory-cards/microsd/ultra-premium-edition/
Actually this is the best that money can buy. It came out a month or two ago. 200gb memory capacity.
May 9, 2015 at 5:02 PM Post #3,322 of 9,972
Can not do much with it yet, as most of the devices support up to 128GB for now...
But promising. :)
May 9, 2015 at 5:32 PM Post #3,324 of 9,972
Hi all,
I ran into an issue with my X3 2nd Gen that I was finally able to solve after 2 weeks, so I wanted to mention in here in case anyone else runs into the same problem.  (I would have figured it out much sooner if I had simply taken the time out for full trial & error!)
I had been using my X3 2nd Gen for roughly 2 weeks with no issues, while using a Kingston 128GB class 10 micro SDXC card (that I had the player format before using).  Then the FLAC files I was listening to started intermittently stuttering (not skipping) for no apparent reason.
It would occur at random, usually between 5 and 30 seconds into playing a FLAC file (which mine are all 24-bit, but vary from 48KHz to 192KHz), but sometimes not until around 60 seconds.  The battery was always either 4/5 full or completely full.  I had read on another thread here that some other FiiO players exhibited this stuttering issue if the FLAC file's attached image was too large, but the ones for my files didn't seem to be.
I played with all of the player's settings (including performing a factory reset) to no avail, and also updated the media library a few different times.  I tried removing and re-inserting the micro SDXC card, which at first seemed to solved the problem, but then the stuttering issue creeped up again.
As a last resort, I temporarily removed all of the files from the micro SDXC card and had the player format the card again, and then moved the files back (and updated the media library).  This solved the stuttering problem.
I now know what may have caused this to occur.  I had completely forgotten (because it just didn't seem memorable at the time) that I had used the player's 'delete whole folder' function to delete a folder off of the card (followed by updating the media library).  Since this was the only 'new' thing I had done, I think this led to the stuttering issue.  Going forward I'll delete folders / files using the computer connected to the player instead.
Hopefully this saves someone here the anxiety I experienced!
May 10, 2015 at 12:32 AM Post #3,326 of 9,972
May 10, 2015 at 7:34 AM Post #3,327 of 9,972
FiiO stated that larger cards should work.  They just can't say supported in anything official as they are un-tested.
yes, otherwise we can also claim that we supports 2T mirco SD card, lol
May 10, 2015 at 12:30 PM Post #3,328 of 9,972
 Recently I had to reset my X3ii 3-4 times... It does not happen if I switch it off completely, but this 3-4 times from deep sleep mode when it wakes up, does not play music. It is completely silent, although on the screen it seems it is playing music, however according to the display, it is jumping in the song by 3-4 seconds onwards...
 Reset always solved this issue, but starts to be annoying.
Also, 2 times out of this 4 I had to update media library, as it did not find any songs after recovery. And lost my 'favorites' list as well...
Anyone experienced similar isues?
May 10, 2015 at 2:37 PM Post #3,330 of 9,972
Can anyone confirm if the volume control on the X3 2nd gen works on the line out (analog & Coax) ?
