seanwee
- Jun 9, 2015
Based on the upgrading trend of FiiO, Im guessing that a X1 2nd gen would be coming out mid of next year.
What do you guys think?
Am I the only person using the new beta firmware 1.61? :rolleyes:
Well, I am trying to use the new "Replay Gain" feature with no success. If anyone is interested in using this feature, I've posted additional details about my test in the thread about beta firmwares at http://www.head-fi.org/t/751039/official-fiio-x1-beta-firmware-download-and-discussion-thread-fw1-61-added-replaygain-and-library-search-function/105#post_12330857
Is it normal that during the welcome screen, the unit is brightly lit for some 5 seconds, and suddenly dims down to a half, when the Fiio logo starts to show off? Haven't changed any of default brightness settings.
It is perfectly normal, the unit always boots at FULL brightness then it dims itself to your set brightness.
Thanks a lot. Feeling already better now, after worrying that my X1 might be fading away.![]()
Can anyone recommend a decent 3.5mm male to 2-male rca adapter to use for line out from my X1 into my receiver?
I've spent way too much time on Amazon trying to find a compromise between the cheap-o units that either break, don't fit well, or aren't shielded properly and the high end units that are over-kill and have RCA plugs that are so tight they are hard to get on and off the RCA connectors on devices.
Any suggestions welcomed.
Thanks!
Thanks!
I still have thoughts of picking up another FiiO X1, (perhaps a black version)
X1 pairs so wonderfully with Sennheiser HD25.
Say what now?
So higher tier gear does not mean better SQ overall?
