sgdan
- Jul 31, 2015
If you are on line out and connect your headphones of turn on the player, a message will appear "Line out may not be connected to earphones..." if you press the back button (upper right) when that message is on screen, an option will appear so you can quickly change to headphone out using the wheel. However I haven't found a way to change from headphone out to line out other than using the settings menu.
