H20Fidelity
- Feb 11, 2012
So for the knob I don't the press the volume control in my X1 I can just use the one on the nx1? Ok I am a noob what does the high and low gain do and how do I decide which one to use?
When using an amp you only use the amps volume control. No need to use X1 volume buttons, in line out mode X1 sends a strong signal (quite loud) to the amp, you just open the amps tap (volume) to let the signal flow so to speak.
Depending what headphone you're using, it's impedance, sensitivity you may need high gain which increases the volume further for harder to drive headphones. You cannot hurt anything so don't worry.
I assume you're waiting for your NX1 to arrive? It's very easy.
1) connect the amp.
2) switch X1 to line out mode.
