Hawaiibadboy
BANNED
^LOL, alrighty then
You will love the bass vid i do with the X1...Seriously you will.
I'll let the thread return to normal programming.....my apologies for the distraction
^LOL, alrighty then
I think I am answering my own question here, but is the X1 (and possibly x5)'s scroll wheel abit loose? I guess that is normal since the scroll whell of an iPod does not really spin at all.
EDIT: Also, how to play random songs (shuffle) through different folders? I can only get it to play songs inside a folder.
so far I like the x1 but to me the clip still sounds better maybe it is just me but I like the looks of the x1 more and the ui
^ That would be very odd if one notch on the slider were to equal 2db.
If that were the case, I would think they would just make it go from -0- to +12 instead of -0- to +6.
I'll need a translator because most of my posts seem to get a new meaning of their own ^_^. I meant the volume setting that is not 1DB for 1unit, not the EQ setting.
I checked again(and happened to have done it right the first time, yeah me!), from 88 to 100 I read about 6db variation, so the mystery that wasn't one is solved.
now 100-88=12
12=2*6
EQ has 6values
now 100-88=12
12=2*6
EQ has 6values
Are you saying that the normal volume level increases .5db per -1- value?
...and that the EQ is adjusted as 1db per -1- value? Thus making 12 clicks on the volume worth 6db and 6 clicks on the EQ also worth 6db?
If not then disregard, I am just trying to interpret what you are trying to say. It's not really clear to me.
Perhaps later someone from Fiio will explain why the EQ and volume truncation is set up the way it is.
Anyone on how to create playlists?
I've just updated my X1 to firmware 1.1.
With this new firmware version there is an option for using cable remote.
I have headphones with a three button remote (XIAOMI Piston V2) which I use usually with my android phone.
On my phone with the middle button i can start and stop music, with the other to buttons I am able to control the volume.
I have now connected this headphones to my X1.
The middle button works fine (one click starts/stops music, double click = next song, triple click = previous song).
But the volume buttons work also identically to the middle button. Is this normal? Do you have headphones with cable remotes that can control volume?
that's about it. yes.
I tried +10 each times and got 5db variations at least from 40 to 100 it worked that way.
but 20 to 30 gave me +10db, and 30 to 40 also +10db. (can't read below 20 because the noise of my soundcard kicks in)
you didn't like my answer to you last time you asked or you didn't see it?
^ oh ok, well if that is true, than I don't know why they don't just make the EQ go to +12/-12 in .5db steps instead of +6/-6 in 1db steps. It would make it a lot less confusing for sure.
I thought that too because initially I thought it worked like an iPod's, but then realized I need to spin it, like those Pioneer CD TT's. I didn't really find it loose, but I regret voting for smooth wheel vs textured back when the initial renderings came out (again, it was because I didn't pay attention and did not realize that it was not an iPod wheel
for shuffle all, you go to "category" and select "all songs". (and you set the replay to shuffle obviously)
Are you...ok? lol are you sure? I mean, how?
