Kees
- Feb 18, 2006
The end of the IC is the plug.
So what's new?
So what's new?
Originally Posted by ziplock /img/forum/go_quote.gif But then you have to worry about shielding, etc... |
Originally Posted by Patrick82 /img/forum/go_quote.gif ! T-Amp is my new reference amp only because the signal path is so short. Even with connectors, it's better than anything else I have tried. |
Originally Posted by Patrick82 /img/forum/go_quote.gif Shorter signal path for power cables gives better sound as well, I have made many experiments. |
Originally Posted by xnothingpoetic /img/forum/go_quote.gif Get rid of the connectors and use ultra short valkyrja soldered directly from one PCB to the other. You could have even shorter IC's and will have less connectors in signal path. |
Originally Posted by ziplock /img/forum/go_quote.gif While you're at it, why not pull out the PCBs from both Source/Amp and combine them into a larger chassis. In doing so, you eliminate any interconnects in the signal path. In all seriousness, it would probably sound quite good. But then you have to worry about shielding, etc... Z Edit: xnothingpoetic beat me to it, sorta... |
Originally Posted by Lazarus Short /img/forum/go_quote.gif You forget that Patrick is masterful with ERS paper. |
