thefitz
- May 22, 2015
I'm buying another powered hard drive - that external one is a good item to have regardless.
You may search for my posts. I have some WD My Passport Ultra, old and new models, 2TB and 3TB. With an external power supply they all work flawlessly. Some formatted with NTFS, some with exFAT, partitioned with MBR. Never tried GPT.Does anyone have any evidence of this properly working with a hard drive? Can someone provide a specific list of models they used?
Thank you - if this doesn't work, I'll try the WD hard drives.You may search for my posts. I have some WD My Passport Ultra, old and new models, 2TB and 3TB. With an external power supply they all work flawlessly. Some formatted with NTFS, some with exFAT, partitioned with MBR. Never tried GPT.
Please note, that for MBR to work with >2TB devices, an HDD should report 4KB sectors. That's what WD does.
I tried (rather old now) WD My Book 3TB, also successfully.
Never tried any other vendors.
Humour me - what external power supply do you use?
Do you have a proper otg cable?
A power bank mostly, or my usual chargers.
How do you use an external hard drive with a power bank at the same time as the player?
Have you already read my previous posts about that?
In brief, there are two options: either a USB Y-cable for HDD, or a powered USB hub. Both can be connected either to a power bank, or to any wall charger.
I thought I did, but all I saw was mentioning of a power supply in general. I'll dig.
Bought these puppies:
Have you tested your USB OTG cable that it works at all, e.g. with a flash cardreader or stick?
If the HDD is formatted with NTFS, I'd recommend you to use my firmware builds.Now onto copying 400GB of music!
