THE DIY HEADPHONE STAND THREAD
Apr 16, 2012 at 12:31 PM Post #1,126 of 3,875
Steel108 is that stand on the left is a holder for something (before it became a headphone stand).  I've seen those around on Head-Fi and have always wondered where you can pick something up like that.  What was it built as and where can a person pick one up?
Apr 17, 2012 at 1:16 AM Post #1,127 of 3,875
posted this in the show your headphone rig thread, but figured i'd post it here too:
2x4 foot 1/4" pegboard, with 4" and 6" hooks and some baskets/tool holders.  total cost of all materials is probably around $60 (with ~40 hooks left over for future expansion/reorganization).  i just got it all together today, so i'm not sure if this is the optimal arrangement, but it's waaay better than before.
Apr 17, 2012 at 2:36 AM Post #1,128 of 3,875
Soooo I'm thinking of making an O2 stand*like the Zebra wood stand* ...what to use, I cannot work wood soooo.
Apr 17, 2012 at 3:45 AM Post #1,129 of 3,875
Anyone else?
Apr 17, 2012 at 12:04 PM Post #1,130 of 3,875
i just bought that white thing from ace hardware, around 50 cent, its cheap,, but its not long enough, and maybe i will put some foam on that thing
and that is my headphones hanging,, sorry for the crappy quality photos,i just took it with my handphone
Apr 18, 2012 at 8:10 PM Post #1,131 of 3,875
Well the copper stand got a bit of "Spit & Polish".
I didn't care too much for the can spray lacquer... If I build another, I'd get it clear coated at a body shop.
Apr 18, 2012 at 9:17 PM Post #1,132 of 3,875
OoO that's sexy! just need a little glass shelf to sit the dac / ipod on...
Apr 18, 2012 at 10:53 PM Post #1,133 of 3,875
Thanks sammcj
A little glass shelf would be nice, but I've never worked with glass...
Apr 18, 2012 at 10:56 PM Post #1,134 of 3,875
Thanks sammcj
It's actually really easy, best thing to do would to grab a cheap picture frame with the glass pre-cut, if it's not thick enough go visit a local glass dealer and ask for an offcut, they'll probably even size it for you!
Apr 18, 2012 at 11:15 PM Post #1,135 of 3,875
I'll check into an offcut at the glass shop, a piece with a little bit of thickness to it.
Apr 19, 2012 at 3:46 AM Post #1,136 of 3,875
Hey, maybe this picture will work:
Best one so far. Didn't realize what it was at first, but then I realized that it was a wrench!
Apr 19, 2012 at 3:48 AM Post #1,137 of 3,875
Apr 20, 2012 at 1:11 AM Post #1,138 of 3,875
Here are my "stands".
My "Buddha Bank" holding my PX-100s
"Fatso" holding my Apex HP 35s
This is a mic stand headphone holder I picked up for $10 holding my Superlux HD668b
This is "Skully" holding my Incase Reflex
Finally this is a TP holder I picked up for $10 which holds my JVC HA-RX700
Cheers,
Dan
Apr 20, 2012 at 2:47 AM Post #1,140 of 3,875
May as well post my stax stand. Had the aluminum bit done at a local welders. The (amateur) leather pad work is mine though.
That's pretty classy...the cable just adds even more class heh.
