joelk2
- Jan 20, 2010
The standard 3.5 mm jack has only 3 solder points. Left, Right and Ground. Nevertheless, if you are using one cable for the right and one cable for the left, you will have right +, right -, left + and left -, in terms that right + and left + are the signal going to the headphone and right -, left - would be the mass or ground. Further you can also solder the cable shield in addition to the ground pin of the jack. But only to the jack..
Maybe this will help you:
http://www.savantaudio.com/wirediag.pdf
Thanks.
i think im right in waht im saying then. you solder 2 ground wires to the ground on the 3.5mm one for each channel
