I managed to do a quick comparison between the original Hugo and the TT. As mentioned, the sound stage is clearly wider on the TT. The sound on the TT feels more 3D like than the Hugo. On the Hugo, due to the narrower sound stage, the music appears to be more intimate. In terms of definition and clarity, I am of the opinion the TT is also better than the Hugo. There is more depth to the sound. This makes the bass and treble much more realistic and enjoyable to listen. On the original Hugo, I sometimes feel that the bass is a bit "bloated" and "loose". I don't feel that way with the TT. However, both the TT and Hugo do share a similar sound signature, IMO.
Other than the sound quality, I like the TT making use of the more standard USB A to B cable and the input switch display. It operates basically the same as the smaller Hugo. So if you are familiar with the original Hugo, you should have no difficulty operating the TT.[SIZE=12.7272720336914px] [/SIZE]
[SIZE=12.7272720336914px]All in all, the TT is a clear im[/SIZE]provement over the original Hugo. Please understand that I am not trashing the original Hugo. It is still a fine sounding device and one of the better ones out there currently. It is just that the Hugo TT is one level above it.
