Dsnuts
- Jun 20, 2011
Will have after pics once I get the dremel out.
You could order them from shenzhen audio, very trusted seller.
I used a round file to make a much larger diameter over the input and headphone jacks and whala..The sound I like to hear.. Scared me for a bit there. I was sure this unit was defective. But this is something to note for future owners of this amp. If your having issues with contact. Take the plastic top portion off. It pops off with minimum fuss and use a round file to make the hole bigger.. Problem fixed.
Basically if the input plug and or headphone plug is not fully in the jack. It sounds muffled. If you guys take out your headphones slightly from whatever soustandard n put you will get the idea. It literally sounds like your hearing music underwater. The hole that I cut out is much larger than the stock hole that sat flush onto the jack openings but raised the mouth of the jack slightly because the thickness of the plastic cover. The problem was that my interconnects and earphone Jacks both had a thicker base than the opening on the plastic cover. I cut out enough diameter to just fit my interconnects and most if not all my earphone and headphone jack bases.
The strange thing about this whole experience was that this didn't happen all this time I was using it and burning in the amp. It happened for the first and last time this morning. It is good that the problem is fixed but this is clearly a minor design flaw. I am sure future versions will be problem free but if it happens to yours at least it is a simple fix.
@Cayin folks. I appreciated the offer for a replacement but I am glad it was just a minor annoyance. So far so good. No more connective issues. Oh and if you guys design a new plastic cover for the top part. I would greatly appreciate one.Just my observation but all you guys really have to do is make the plastic part sitting over the input and headphone jacks just a bit thinner but use a better more ridged plastic so it sits slightly below the lip of the headphone and input jacks. I am sure you guys will figure it out.
I though you meant DX90 as that is what I have. I sold off my DX50 when I bought my DX90. I have no doubts it will sound great using the DX50. I did hook it up to a lesser player in the Z1060 and that sounded great. This amp magnifys the sound from your line out. From memory with the last firmware I installed on the old DX50 I used to own it has more of a neutral signature than anything with too much coloration. Which is pretty much what my DX90 is. I seriously have no doubts it will pair with the DX50 very nicely. The C5 doesn't add much in the way of coloration..It projects the source sound signature more so than anything. It does seem to add a better sense of sound layering and space in all directions, more rangier vocals, instruments, bass, but does not tilt the sound toward any particular sound bias. Well that is as long as you stay off the bass boost.
Hi Thomas, thanks for your attention and help. Excellent Customer Service! Would be nice if you could inform us after the changes in production have been applied and which distributors are going to have the new versions.
