Mochan
- Jun 3, 2009
If you go for the 600 Ohm versions you might need an amp that can drive them as well. I am not a believer of the whole 5.1 CMSS3D type of things. To be honest, a 2 channel stereo headphone is all you need. I have experimented with the above listed technologies but I never found them pleasent or improving.
Since you live in Holland, as where I live as well! You can audit various headphones as I did. I went to Hobo HIFI in Den Bosch. And then you have RAF where you can listen to some cans as well. I'd go for a Beyer or Audiotechnica. I have also listened to the DT 880 which is analytical, great for gaming! You don't need a lot of bass for pinpointing. Sound needs to be crisp and clear.
Good luck!
Have to totally disagree with this. The 5.1 CMSS 3D thing makes a huge difference in 3D positional sound. It's not designed to make music sound better, and indeed i turn it off when listening to music.
But for 3D gaming it is a necessity if you are using stereo headphones. Stereo doesn't even compare. Stereo can give you a good idea of left to right positioning on a flat horizontal plane in front of you, but absolutely cannot put sounds behind you. CMSS 3D HP can put the sound behind you with remarkable accuracy. Using stereo headphones.
Have you tried the difference in 3D games? Believe me it's a huge difference. I saw a lot of threads on this forum about how the AD700's massive soundstage lets them hear exactly where all opponents are and this is bullcrap to be honest (and they say they run it out of a normal soundcard and not use either Dolby HP or CMSS -- again that's BS. Also heard a few people claiming how Dolby HP let them hear the footsteps of their opponents all across the map -- whereas without DHP they can't hear it -- again that's crap neither DHP or CMSS3D create sounds out of nothing) So be careful reading the exaggerations you will find on this forum.
Personally I still prefer gaming on 5.1 speakers but if have to keep it quiet for the sake of your neighbors, your roommate, or whoever, CMSS 3D + a good headphone is the ticket.
