Who?
- Dec 29, 2008
If you go for the 600 Ohm versions you might need an amp that can drive them as well. I am not a believer of the whole 5.1 CMSS3D type of things. To be honest, a 2 channel stereo headphone is all you need. I have experimented with the above listed technologies but I never found them pleasent or improving.
Since you live in Holland, as where I live as well! You can audit various headphones as I did. I went to Hobo HIFI in Den Bosch. And then you have RAF where you can listen to some cans as well. I'd go for a Beyer or Audiotechnica. I have also listened to the DT 880 which is analytical, great for gaming! You don't need a lot of bass for pinpointing. Sound needs to be crisp and clear.
Good luck!
Good luck!
