Sonicpath
- Jan 4, 2009
very nice that looks "MACHO"
Originally Posted by ghostmusic /img/forum/go_quote.gif I haven't heard iriver/D10 combo, but judging from Sasaki's take on it, I got the impression that it's not exactly a world beater. It seems that without rolling op-amps and bypassing buffers, D10's amp is underpowered and doesn't tap the full potential of the DAC... and even with op-amp rolling, I doubt you can fundamentally change how it sounds? I'll wait for his further impressions... |
Originally Posted by Sonicpath /img/forum/go_quote.gif Just a stupid question. If I use H140 optical out then the rockbox EQ won't be effective. right? |
Originally Posted by qusp /img/forum/go_quote.gif thats an interseting question. that depends I actually would thionk you would. I can use rockbox EQ with ipod lineout. as I think the processing is done pre dac stage when its being decoded. |
Originally Posted by Sonicpath /img/forum/go_quote.gif I've done my research now, I want to put up an Ideally best portable gear setup see If anybody agrees COMBO 1 ---will cost around 900+ USD Source component: iHP-140 rockboxed with 120HD MOD Portable HeadAMP: iBasso D10 Headphone(no custom): Westone 3, Shure SE530, IE8, UE 10pro. COMBO 2----will cost around 750+ USD Source component: Ipod 5.5MOD rockboxed Portable HeadAMP: P51 Headphone(no custom): Westone 3, Shure SE530, IE8, UE 10pro. See if anyone have any better setup for now |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I need someone who can put an 80gb or 120gb drive in my iRiver. But, the iRivers are easy to kill with the wrong charger or just back luck, so it's possible that it will never power up again after the hard drive mod. Oh well... |
Originally Posted by dazzer1975 /img/forum/go_quote.gif I'd recommend a cf card adaptation or even a cf to sdhc adaptation IF you are in no desperate need for more storage right now as ssd prices are dropping all the time. Im waiting till 64 gig cards drop to roughly the price 32 is at the moment and ill be making the switch. Although, with literally ten minutes of your time and the right screwdrivers you could change the hdd yourself. Wap the back off, move the battery and take out the hdd and replace...As you have rockbox already installed its job done. Whats the issue with yours not turning on again? Have you used the wrong charger? |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif No, but it is a very frequent mishap, and I did have one die by plugging it into the right charger. |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif I need someone who can put an 80gb or 120gb drive in my iRiver. |
