The Audio Technica W3000ANV Thread
Oct 23, 2021 at 2:35 AM Post #1,516 of 1,525
purk
So are you saying they wired connectors into your headphones or removed the connectors from that cable and wired the cable itself into your headphones? Would love to see a photo of the finished job. Either here or by p.m. Thanks
I think he meant to hardwire the cable directly onto the driver.
Oct 23, 2021 at 2:41 AM Post #1,517 of 1,525
milkdudd
Yes he pm'd me a photo that indicated just what you said. It gave me an idea. I thought to convert my anniversary models I would have to cut the cable and splice in new wires. Or alter the cups to install connectors. I just looked at them and I think if I carefully remove the existing cable I could wire in a balanced cable without altering the cups. I would just like to have the opportunity to return them to original. The value of these hasn't gone crazy high but they still are collectible in my opinion. And the ability to return them to original condition would be a plus
Oct 23, 2021 at 11:45 PM Post #1,520 of 1,525
ozz007
Just replace the original cable with the new one. No cups modifications require.
You will have to cut the connectors off, then solder the wire to the drivers.
Oct 24, 2021 at 12:06 AM Post #1,521 of 1,525
milkdudd
Thanks. Good to know it wouldn't require modification to the cups. When you say cut the connectors off do you mean slip on connectors inside of the cups that attach the cables to the drivers? I wouldn't want to cut any part of the cable that shows outside of the cups. I'd love to see internal photos of these headphones or a similar Audio Technica closed model
Oct 24, 2021 at 1:25 AM Post #1,522 of 1,525
ozz007
You don't cut the original cable. You removed it. If your new cable has any conectors removed the conectors, then solder the wires to the drivers.
No modification to the cups at all. You can reversed if you like later.
Oct 24, 2021 at 3:14 AM Post #1,523 of 1,525
purk
Yes, I did this myself and use a Moon-Audio Silver Dragon as an upgrade cable. One will need to remove the earpad, then remove four screws and the wooden cup should come off the frame. Then remove more screws to gain access to the back side of the driver, desolder the stock wire, and then hardwire the upgrade cable. Should be a sonic improvement.
Oct 24, 2021 at 12:39 PM Post #1,524 of 1,525
ozz007
Yes it is. An improvement
Oct 24, 2021 at 1:51 PM Post #1,525 of 1,525
milkdudd
Okay thanks very much, tells me everything I need to know. I'm guessing removing the pads is simple, maybe just twist and they come off? Thanks again
