Hi
RCA 6SN7GTB data code ML. Any ideas about Year of made?
Apparently that's a shipment date. October 1961.
Hi
I am confused on tube readings when I am buying used. A popular tester gives results like 2500/2400 where 2600/2600 is typical new/best. I use to think it was 2400 out of 2500, but now I think those numbers are 2 different parts/aspects of the tube. Can anyone enlighten me on this?
Thank you.
Those are Raytheon VT-231 era 6sn7gt , 1940's.I came across these Tung Sol 6sn7gt's and was wondering if anyone can tell me a bit more about these
What period? Same sound as mouse ear version?![]()
Yes.Hello, can anyone verify that this is considered a Sylvania 6SN7GT "bad boy" ?
Originally Posted by Frihed89 /img/forum/go_quote.gif
It is my understanding that only a small fraction of the Slyvania JAN-CHS-6SN7GTs are "bad boys". Is your description of the JAN-CHS-6SN7GT or the bad boy part of the production run?
If you are describing the bad boys, then how do the other JAN-CHS-6SN7GTs differ in construction from the bad boys?
Hi there -
Bad Boys were only made in
- late 1951
- 1952
- early 1953
Thus they will be marked with either
- '1xx' (late week production numbers only),
- '2xx' (all 52 weeks of the year) or
- '3xx' (early week production numbers only)
date codes.
They can also be JAN-rated and thus be marked JAN-CHS-6SN7GT.
For construction details, look to the section on Bad Boys in post #3 and compare against that for 'normal' Syl 6SN7GTs.
Hi
Any idea about data of production Sylvania Gt vt-229?
Thank you that makes sense, so how big of a deal is it when the number get far apart? like if you have a tube rated at 2500/2200 and 2600/2600 is "peak", is that tube "unbalanced"? Also, is there a reason 1 side would degrade faster than the other?
Just a labeled for the military 6sl7gt, prob 1941-45.Hi
Originally Posted by augustwest /img/forum/go_quote.gif
adhoc -
I have a 6sn7 tube that I am hoping you might help me identify? It is a brown base, medium bottle with trianlular black plates. The only indentifing markings on it are "6sn7 / Tele - Rad" in small point type face.
- augustwest
Hope ya got my email.![]()
If the spam filter ate it, it's almost certainly a Tungsol WGT or WGTA.![]()
