OK, maybe "whack" is too strong a word. Gently tap, tap, rap... in my experience that affects the crackle/buzz, and sometimes clears it up. Sometimes the crackle/buzz will return. Whaddaya gonna do. Obviously you don't want to hit it so hard as to break the glass, but tube glass is pretty thick, at compared to a light bulb. So, if you hear the crackle/buzz, give the glass a light tap and listen for a difference. If it's only one tube, you'll need to know which tube feeds which channel (e.g., in the Schiit Lyr, Left is front, Right is rear). Anyway, easy enough to tell when you start tapping. Since this type of crackle/buzz is apparent without any audio playing, it's best if there is none. Makes it easier to hear the effect.
