Beestonite
Thank you very much for that information, you may just have saved me a lot of problems.The Darkvoice 336se uses a 6N8P natively which is similar to a 6SN7. The 6N7 has a different pinout than the 6SN7, so an adapter would be required at minimum. The 6N7 also draws much higher heater current than the 6SN7 (or 6N8P), so even with an adapter it may be very risky to use depending on the max current the DV can handle safely.
