- Oct 14, 2013
THANKS FOR SHARING ,, ONE OF THE BEST MODS FOR TH-900
I am glad that you love it
my th900 foam were glued..
anybody glued also?
Lol! Mine were never glued and so as many others, when did u buy your ? Was it new ? If so when was a it manufactured ?
I bought from My friend last week who just use it around 2 hours. He bought it brand new about 1 or 2 years ago and not the mk2. Serial number is 1100. Just now I asked him, he never open or do mod to the headphone, when the package arrived, open, listen and back to the box. Hmm.. strange
You using a dap, amp, ?I purchased a used TH900 MKII. I found the treble mostly unbearable, with strong sibilance, even after performing all of the EZ mods, (including rotating the white stuffing in the cup). Some vocal recordings on YouTube were painful to listen to.
I wanted to put an additional filter in front of the driver, so I ended up cutting a pair of circles out of Bounty paper towels. The circles are smaller than the outer diameter of the foam disc, but larger than the inner diameter. I used the paper tape to affix the paper towel filters to the back of each foam disc, pulling the paper as tight as I could while taping it down:
This, surprisingly, solved all the problems I was having with elevated treble. I don't know if there are any long-terms issues in doing this (like lint buildup), but the immediate results are very good.
Could just use eq and lower the treble. The TH900 works great with a good eq.I'm using a Schiit Bifrost Multibit and Asgard 2.
