Aug 25, 2011 at 2:23 AM Thread Starter Post #1 of 9
gled10
Long time lurker first time poster!
My set up:
Foo bar 2000 (WASPI OUT) -->
-->USB 0404--->
--->Darkvoice 3322--->
--->Sennheiser HD800
I am a audiophile in search of better sound. What is my next upgrade?. I love the HD800 and I am looking for something to compliment them. Any advice is appreciated. Thanks!
Aug 25, 2011 at 2:29 AM Post #2 of 9
Depends how much you want to spend.
HD800 stock sound with a good amp are best for classical.
So the opposite would be more bassy and forward.
Denon
Ultasone
would be good
Other alter:
GS1000i
Ps1000
HD600
T1
You could also look here for a good break down of the Flagships
Aug 25, 2011 at 2:53 AM Post #3 of 9
Thank you for your reply. I should of been more specific. I love the tube sound of the DarkVoice. I listen to mostly rock and hard rock and acoustical guitar. The HD800 are completely neutral sounding, looking for something that will give it a little color. I am looking for either a amp or a DAC upgrade. Whichever will give me better sound.
Aug 25, 2011 at 4:15 AM Post #5 of 9
Woo Audio 22 and a balanced cable.
Aug 27, 2011 at 10:55 AM Post #7 of 9
How about a source upgrade as well?  Upgrade option include:
Benchmark DACs
Burson Audio DA-160, HA-160D
CENtrance DAC Mini CX
Aug 31, 2011 at 1:54 AM Post #8 of 9
Thanks for the suggestions. I heard the way to upgrade is headphones -> amp -> source, for best sound. So I believe after an amp upgrade I'll go for a source upgrade next. Man this hobby gets expensive.
