@Dixter : I would recommend to look into connector option to match majority of your other IEMs/CIEMs. After market cables are not cheap, so if you are planning to invest money into the upgrade cable - might as well share this resource among your other headphones.
Review units came with a stock cable which is not bad at all, and I'm sure a lot of people will be fine with it. I don't have an experience with Thor cable, but do with Linum and used my own BaX for testing. The improvement with BaX is really on a level of refinement with a little brighter and a bit more detailed sound, and tighter low end. Other silver plated and pure silver cables with have a similar effect. From my own personal experience, silver-based cables pair up better with neutral and warmer signature, while regular ofc or pure copper warms up/smooth out brightness of analytical sound sig.
I provided a picture of Ei.xx with BaX before, here it is below again. Cable is super thin, nearly disappears by blending with your skin. But at the same time, they are a bit hard to manage due to a slight memory effect of the wire and some tangling. Also keep in mind, with a regular cable or any other thicker cable upgrade, you get some kind of a memory wire which is easy to grab when you are removing CIEMs. With BaX you don't need memory wire, which could be a bit of a challenge at first to figure out how to take CIEMs out of your ears with a clock-wise twist (I found it easier when I grab a tip of the connector with my fingers). Everything has its pros and cons, when it comes to sound improvement BaX definitely steps it up.
