Sorry up front if I'm asking dumb questions... because I'm a bit confused ...
One of the drop options is for the Effect Audio Thor SPC cable.... this is not a Linum cable ?
nor do I see a Linum cable as an option... this would exclude the Linum capabilities to enhance the CIEM ?
The test units that were sent out for review... what cable is on them ?
I only ask because the connector choices are options for a Linum cable... and a link to the Linum website was supplied on the Drop Comments page to show the different connector types....
a few considerations exist there...
do I want a Effect Audio Thor SPC cable or a Linum cable? I'm thinking they will sound different with these CIEM
do I want a cable connection that matches my other CIEM so I can swap cables
Well, the selection of cable standard in the order form is a bit troublesome.
Thor is not Linum, it's Effect Audio. So technically you cannot have "Linum T2 Effect Audio Thor" even though such combination is possible to pick in the order form.
What other CIEMs do you have? The most popular is still 2-pin which we use as default option.
Review units were sent with standard cable.
