daid1
- Jul 15, 2013
I haven't seen a 3.5mm balanced connector before. It's always been either 2.5mm, 6.35mm or XLR.
Sorry I mean 2.5 to 2.5mm trrs, but yes there is also 3.5mm trrs
No.Hi BenF, did you try Fiio Q1 ii with O2 amp?
I bought one from vention also, the 2.5mm part can't go into the hole fully. Must cut the tip of the housing a bit to make it useable.Well, I bought a 2.5mm to 3.5mm from Vention, hoping it to be decent, but totally not worth it. I suppose the cheap cables are off for me. Can anyone suggest a decent to good cable with 2.5mm to 3.5mm? Something that doesn't "robotize" the sound of the 82 Pro (yes, they were that terrible).
https://www.aliexpress.com/item/Upg...ack-Cable-Mic-For-Bose-Quiet/32810246600.htmlWell, I bought a 2.5mm to 3.5mm from Vention, hoping it to be decent, but totally not worth it. I suppose the cheap cables are off for me. Can anyone suggest a decent to good cable with 2.5mm to 3.5mm? Something that doesn't "robotize" the sound of the 82 Pro (yes, they were that terrible).
I noticed that I had to not insert the 2.5mm pole fully to even get sound on both sides, and if I got it all in, it would completely stop. How's the sound quality on yours after cutting the tip? Can you upload a pic of it?I bought one from vention also, the 2.5mm part can't go into the hole fully. Must cut the tip of the housing a bit to make it useable.
Probably will buy this one then, or similar. Want something smaller than the current one though.
The only reason why I'm not buying this one, is because it's too similar to the original one, and my current cover doesn't allow me to properly insert the 3.5mm pole in the socketThis one works just fine for me, I didn't hear any "robotization" effect with it, couldn't tell the diff between it and the stock cable, and it fits fine into the Pro 82 without any issue:
https://www.amazon.com/gp/product/B01115SWBG
https://www.head-fi.org/threads/tak...iscussion-thread.849965/page-47#post-13939639I noticed that I had to not insert the 2.5mm pole fully to even get sound on both sides, and if I got it all in, it would completely stop. How's the sound quality on yours after cutting the tip? Can you upload a pic of it?
One for each Pro 82 ever made?We crossed 1000 posts today!
