alkalama
Did somebody test it with Chord Hugo?
If you mod them with foam pieces what BenF did you can get rid of the thinnesIt might be a matching thing with the amp. The Pro 82 bass increases with a higher output impedance.
It’s thin even with a bass boost switched in?
I don't know, it has been awhile since I use the Pro 82 with Chord Mojo. I'm using it with iDEA + O2 + cotton roll mod, it doesn't sound thin at all.It might be a matching thing with the amp. The Pro 82 bass increases with a higher output impedance.
I own neither of the M50X and M40X. But I do live close to an audio store that allows its customers to try out audio gears (headphones, DACs, amps, DAPs etc.). I had a few comparison sessions with all three of them using a Chord Mojo. I thought the M50X is too sibilant for my tastes, the Pro 82 is too thin sounding like I've mentioned before and M40X is fun sounding without being fatiguing over time. I recommended it to my brother who ended up buying it, and I've been borrowing it from him whenever I'm traveling far from home. The Pro 82 never really had a chance to leave the office, I'm using it mainly for gaming (while working ) and some casual music listening.Can you please do a slightly more indepth comparison between the 3 headphones you just mentioned?
Actually, Random54 proposed it (linked in post #3):If you mod them with foam pieces what BenF did you can get rid of the thinnes
I doubt it. I don't think anyone on AliExpress had any white box version (first batch) left in stock.but it should be the white box version.
Oh right, I meant black. The white was from HeadphoniaksI doubt it. I don't think anyone on AliExpress had any white box version (first batch) left in stock.
Better than tomtop order it from aliexpress for 62$Has anyone here bought the PRO82 from Tomtop? Are they fake/legit? I've bought from Tomtop before (xduoo daps) and had no problems other than the delays but since the warnings from not buying in another place than takstar store i'm a little concerned. Also, don't know why Takstar store wont ship to my country
Does this applies to takstar 80 to,and if it work does it have to be cotton or i can use also toilet paper roll?.You said smth that would make takstar 80 sound similar to 82 with a mod,but cant find it help would be apreciated,unless it was this one with coton.Actually, Random54 proposed it (linked in post #3):
Random54's initial impressions (including cotton ball mod for the pads)
